Miguel Vidal RV-8
Date:  6-2-2014
Manual Reference:  8s7-1r11 (7-7)
Brief Description:  Assembling and Sealing the Tank (LH)
Cleaned off excess proseal from inboard rib, both sides with acetone. Installed nutplates around access panel reinforcement ring. Sealed around nutplates and rivets with proseal.
Made fillets of sealant at the joints of all mating surfaces of access panel reinforcement ring, T-405 and T-710.
Fay sealed VA-112 Fuel Drain Flange to tank skin and 100% clecos. Left pieces to cure overnight.
Sealing installed nutplates in reingorcement ring
All nutplates covered with Proseal
Installing VA-112 Fuel Drain Flange
