Miguel Vidal RV-8
Date:  6-10-2014
Number of Hours:  0.20
Manual Reference:  CFQS OP-7
Brief Description:  Installing Capacitive Fuel Quantity Sender (LH)
Cut a piece of 18 AWG wire to 48". Stripped one end and installed a wire terminal. Attached the terminal end of the wire to the outboard sender plate. Installation of terminal suggested to be both soldered and crimped for added durability. Tested the security of the wire to terminal connection by applying an approximate of 20 lb. pull test load.
Refered to DWG OP-7 Fuel Tank Top View for attachment hardware and installation details.
Refered to View A-A to orient the terminal relative to the outboard sender plate.
Outboard Sender Plate wire terminal installed before Proseal application
