Miguel Vidal RV-8
Date:  6-5-2014
Number of Hours:  1.00
Manual Reference:  CFQS OP-7
Brief Description:  Installing Capacitive Fuel Quantity Sender (LH&RH)
Cut two pieces of 18 AWG wire to 15". Stripped one end of each wire and soldered to the LH & RH BNC bulkhead connector, respectively.
Used heatshrink for added protection and applied a coat of sealant to final seal the exposed soldered ends of the BNC terminals and wires, so no exposed bare wire or solder is exposed.
Both LH & RH BNC terminals ready for Proseal
