Miguel Vidal RV-8
Date:  3-15-2014
Number of Hours:  0.70
Manual Reference:  Duckworks HID 24-4
Brief Description:  Installing the Reflector Mount (LH)
Final-drilled for nutplates and ballats holes. Deburred, dimpled, cleaned with Mineral Spirits, and primed reflector mount. Used Krylon Gray Paint+Primer for better light reflectivity.
Installed Ballast, igniter, and cables on Reflector Mount.
Set aside for plexyglass installation before final mounting on Leading Edge.
Reflector base, ballast, and cables mounted
