Miguel Vidal RV-8
Date:  3-12-2014
Number of Hours:  0.50
Manual Reference:  Duckworks HID 24-3
Brief Description:  Working with Ribs (LH)
Fit the Rib-Shaped Template B into leading edge of #4 (before outboardmost) LE rib.
Marked the 2 locations on rib according to template.
Drilled the 2 holes with #30 drill. Used rib as template to back-drilled on outboardmost (#5) rib for exact mirror-like alignment.
Used clecos to attach nuplates in holes and final drilled #40 nutplates holes using nutplates as guide.
Drilled the screw holes for the nutplates using a 3/16 drill bit.
Deburred all holes.
Cleaned with Mineral Spirits and Primed ribs
Riveted the 4 mounting nutplates using AN426 solid rivets.
Installing mounting nutplates
