Miguel Vidal RV-8
Date:  10-29-2013
Number of Hours:  0.40
Manual Reference:  OP46-02
Brief Description:  Installing Stall Warning System
Clecoed the VA-195C Access Hatch Doubler to the W-701-L Wing Leading Edge Skin.
Match-drilled #40 all holes in the area using LE skin as a guide.
Final-drilled #40 nutplate attach holes aling the inside edge of the access hatch doubler.
Removed the reference tabs from the VA-195C Access Hatch Doubler.
Clecoed Access Hatch Doubler to LE skin
Access Hatch Doubler (inside view)
Access Hatch Doubler clecoed and match-drilled.
