Miguel Vidal RV-8
Date:  10-21-2013
Manual Reference:  8s7-1r11 (7-4)
Brief Description:  Fitting the Wing Walk Doublers (RH)
Fabricated W-727 RH wing walk doubler out of .025 Aluminum sheet. Aligned to main inboard wing skin and match-drilled doubler with the rivet holes on W-702-R main top inboard wing skin as guide. Clecoed the doubler and skin to the wing rib assembly for match-drilling to ribs.
Match-drilled wing walk doubler to ribs and spars using RH wing skin as guide.
Unclecoed and deburred wing walk doubler, dimpled, cleaned with MS, and primed
Deburring RH wing walk doubler
Dimpling doubler
Dimpling doubler
Priming
Priming
