Brief Description: Preparing the Main Spars (LH&RH)
Removed the tiedown and spacers from the spars, clecoed them together and drilled the holes for the platenut rivets, using the platenut as a drill guide. Riveted the platenuts, spacers, and tiedowns together and bolted the corresponding assemblies to the spars for test fitting.
Removed the assemblies, disassembled them, deburred, and primed the parts before putting them back on together with the W-823PP aileron bellcrank brackets.
