Measured and drilled top & bottom holes on HS-801PP LH & RH skins for CS4-4 blind rivets that will attach HS-615 LH & RH molded fiberglass tips. Match drilled new holes to fiberglass tips. Minimum required pitch & edge distances taken from MIL-R-47196A.
Match drilling holes after measuring proper distances
