Miguel Vidal RV-8
Date:  6-14-2012
Number of Hours:  0.80
Manual Reference:  8s6r12 6-3
Brief Description:  Riveting Horizontal Stabilizer
Riveted HS-404 (LH & RH) and HS-405 (LH & RH) to FSA.
Offset rivet set used so ribs where flexed out of the way as little as possible in order to reach rivets.
Skelleton was re-primed the following day to protect the rivets and damaged primer areas by the riveting process.
FSA and Ribs ready for riveting
FSA and ribs riveted together
Final frame priming
Final frame priming
