Labeled LEFT/RIGHT for Front Spar Assembly (FSR) according to HS-810-1 and HS-814-1 reinforcement angle bars orientation to HS-702 front spars. Drilled and match drilled (existing holes) inboard of HS-404 & HS-405 attach points and HS-810-1 & HS-814-1 bend lines. Marked with Sharpie the location for further reinstallation of HS-810-1 and HS-814-1 to HS-404 & HS-405. Measured, marked, and prepared both sides of HS-810-1 and HS-814-1 for tampering and rounding off edges.
