Received the AML 34 switches in the mail today. Figured since I am still waiting on the fuselage to arrive I might as well start soldering the light connections. I Soldered the ground side of the light to the second pole of the switch so it is now switch position dependant. Pretty simple. Also installed the various color lights I plan to use. I found with some of the small LED lights that I had to clip off a small plastic nub at the bottom of the light to allow for it to make contact in the switch. Once I figured that out then they all worked well.
