Bounced around a bit today, but was able to re-solder the wiring in the yaw trim switch for use with the G3X module. I used proseal to secure the pitot tube before riveting it with the bottom wing skins. Finished the left wing bottom wing skins and hooked up the wiring / bent the tubes on the GAP 26 Pitot tube. Then mounted the flaps and airleron before doing the rigging process and installing the push/pull tubes. Had to make a couple turns on the control rod ends to adjust the rig, but all worked out. also, ended up having to move some of the pitot tubing to eliminate interference with the wiring / control tubes. Torqued everything down and tucked it away until having to remove it again for paint later on.
