Finished leak testing the right fuel cell. The only leak I could find was the test baloon, so hopefully all is well as the soapy water didn't reveal any leaks.
I then deburred all bottom wing skin parts and drilled the AHARS mounting bracket. Not much else I can do on the bottom wing skinds until the wings are assembled.
Deburred all the Flap components and most of the Airleron components. Quite time consuming, but will make section 21 and 22 fly by as I get there.
