Long day of building up the left wing same as I did the right wing last weekend. Cleco'ed the Ribs to the main spar to include the rear spar and top skin. Drilled all the appropriate holes and then spent much of the day deburring.
The 3rd picture is the CPC holder that I fabricated to replace the Molex pin holder that comes in the kit. This one will hold two 9 pin CPC's and an RG-400 Coax bulkhead fitting. Not a hard mod and it will cleanup my wiring at the wing root significantly since I am not using molex.
The 1st picture is drilling the wing system electrical and pitot holes in the ribs. Once I assembled everything I spent some time deciding where and how I wanted the elctrical and pitot wiring to minimize interference between power and data wires along with not haveing extra holes that go unused. Took a bit of time to plan, but well worth the effort. I did have to buy a few extra Plastic bushings, but nothing a trip to aircraft spruce can't solve.
