Completed riveting the rollover bar structure and got to work on making the mounting surface for the baggage compartment LED light. Worked pretty well and I put the switch on the side of the upper support structure so it wouldn't be accidentally hit by baggage going in and out. I then match drilled the roll over bar to the mounts and finished mounting the structure with the exception of the last 10 rivets.
While adjusting the squeezer depth on my pneumatic squeezer I accidentally activated the switch and tried to squeeze my fingetip. Luckily it was flat dies instead of dimple dies. Only 2 stricthes and no broken bones, but had it been a dimple die I likely would have lost the fingertip since I squeezed the dead center of my meaty finger.
