Brief Description: Fwd Mid Fuselage Side Structure
Finally got a full day to work on the airplane. Started with alodining many of the fuselage parts and then started on the riveting. The match drilling of the side skin is pretty extensive, but wish I had done much of the countersinking the side plate prior to alodine. I ended up using the 1132 pen to alodine the countersinks, but it doesn't get the center of the hole. Good enough though. Lots of deburring and side skin prep. Next step is dimpling the side skin before assembly
