Flying Lead RV-14A
Date:  8-25-2019
Number of Hours:  2.70
Manual Reference:  33-7
Brief Description:  Rudder & Brake Systems
Decided to dig into the brake system and got all the hoses setup with the correct fittings. I used Earls Speed-flex -3 hose with a smoke PVC jacket along with Speed-Flex fittings. Earl's had a YouTube video that explained installation and I simply followed the steps. Since the termination is similar to the vans hoses I mostly used their lengths from the instructions with the exception of the gear leg hoses and brake fluid reservoir to co-pilot pedal hoses since I have 45 or 90 degree fittings that changed the length of the hose by about 1". I got everything fitted with the exception of the pilot side brake to gear leg hoses which have one end un-terminated. This is because the hose must first be run through some pretty small access holes and it wouldn't fit if the hose end fitting were in place. I'll finish that one after I install the line, but all others are complete. Now I just need that Fuselage kit to appear in the driveway.
