Continued on the build with the flaps. Lots of little edges and corners to deburr. Also made one mistake where I drilled #30 holes in the flap attach brackets instead of #40. Likely no big deal as I can just use AN4 rivets, but they are supposed to be double flush so we will see how that turns out. Fully assembled both flaps and will continue with final drilling the trailing edge next session. I plan to order the fuselage kit tomorrow as I am moving right along.
