Flying Lead RV-14A
Date:  4-14-2019
Number of Hours:  5.40
Manual Reference:  17-2 to 17-5
Brief Description:  Outboard Leading Edge
Spent today starting the outboard leading edge. Having previously deburred the skins I was able to go straight to drilling and deburring the ribs which took a significant amount of time. I then assembled the right wing and match drilled the holes in the J-stiffener. Will do the same to the left wing next session.
I am going quite a bit out of order from the plans because I have a choice of either assembled wings or my vehicle in the garage. As such, I am going to do all the prep I can before assembling the main spar since at that point my truck no longer has a covered parking space. I figure I can get through assembly of the outboard leading edges, fuel tanks, flaps, and airlerons before I need to assemble the main wing spar.
