Flying Lead RV-14A
Date:  4-5-2019
Number of Hours:  3.80
Manual Reference:  T-5 & T-6
Brief Description:  Electrical and Avionics
Received my landing and taxi light in the mail along with the trim servo connectors. Pulled about 7 Amps each for the Taxi and landing light. Spent a few hours attaching the trim servo connectors in the tail section before I put on the final empennage skins. Image two is my first of many CAN bus connections. I did not ground it at this point, but adding a ground wire for the shields wouldn't be difficult.
It is great having the 3D printed mockups of the Garmin components. Only problem is trying to hold the connectors about where they should be while routing and zip tieing the wires in place. I have a bit more adjustment to do on the tail wiring harness, but it is coming together.
Finished the wire routing and ziptied everything in place. I am sure I will have to cut the ties and change something once flight control tubes and Servo's are installed, but good for now.
