Bounced around quite a bit today since I wanted to do a full spar assembly and dissasembly to keep the garage available for truck parking. Started with match drilling of the rear spar doubler plates before assembling the wing ribs on the right wing main spar. I then match drilled all the spar to rib holes along with the rear spar to rib holes IAW the instructions. Next will be prep and attachment of the wing skins before dissassembling the right wing and deburring. I plan to then do the same on the left wing before priming everything. Lots of deburring on these wings, but all worth it now that I see them coming together.
