Got the drill press so i decided to get all the holes drilled in the aileron push pull tubes. A couple lessons learned on drilling straight holes in pipe, but no mistakes. Everything is drill and deburred, just needs to be scuffed, cleaned, and primed before assembly. I'll get a little further along with the spars before mixing the primer. A bit out of sequence, but easy to do since it didn't require any other parts to have been previously built.
