Flying Lead RV-14A
Date:  2-23-2019
Number of Hours:  4.70
Manual Reference:  10-31 & 23-3
Brief Description:  Empennage
Jumped around a little bit today due to Elyse's nap time and riveting making too much noise. I ended up back riveting the upper skin to the longeron then finishing the curved area with gun and bar. Had to drill out about 7 rivets because i failed to push the skin flat against the back rivet plate, Dumb mistake.
In between riveting I ended up cutting the bar stock to length for the wing aileron control tubes in preperation for dilling and priming. I am jumping ahead because I want to prime the inside of the steel tubes before they have a chance to rust in storage. Also need to buy a drill press to properly drill the holes in the tubes.
