Lots of crawling and bending underneath this beast. Also, quite a few odd angles that required some thinking to work the Geomentry of the bucking bar. Used my first two "oops" rivets for a couple odd angles that had to be drilled out more than once. They do work well when needed. Also had to do some forming of the aft portion of each side skin to get a tight fight on the aft bottom fuselange skin. It is all coming together so far. Tomorrow I will try to get help from a neight for the bttom rivets on the curved portion of the side skins. It will be easier to do those with the fuselage tipped upside down.
