Finished riveting the front spar and counterbalance skind on the right and left elevator. Primed the backs of all the rivets then used proseal to emplace the trailing edge foam re-inforcements on he left elevator. Used the tape and clecos on the trailing edge and will let it sit until tomorrow on the bench before doing the same to the right elevator. While I had the pro seal out I place some in the end of the rudder trailing edge to help bond the skins and close up the area that has a high propensity for water intrusion. Looks like it will turn out well.
