Continued along on the plans today with lots of riveting. Built the structure for the elevators and also fabricated the fairing for the elevator trim servo pushrod. Some odd angles to rivet but ultimately not that bad. Had to adjust a few rivet lengths from the plans as they just didn't quite seem right. Will prime the rivets tomorrow and close up the elevator. Taught the neighbor Jaydon to install and remove cleco's. Took some extra time at first, but he is starting to speed up the process. Although, teaching others about the building process and aviation is half the purpose of the build, so time well spent regardless of the extra work.
