Continued to debur the edges of the skins before bending and trimming the final pieces of the elevator assembly. Assembled the spars and stiffeners before clamping and drilling the piano hinge used for the elevator trim tab. Ended up having the piano hinge offset about 1/2 inch which resulted in some differences in the drawing where it should be trimmed to fit, but ultimately I don't think this will matter since it is simply a inge and only mates to two surfaces. No other issues, but I can see already that bucking the trailing edge spar is going to be a pain in the but even with the special bucking bar.
