Completed installation of the rudder trim servo fairing and routing of the electrical cable. Will eventually run the wires through a 9 pin CPC connector at the aft end of the fuselage. Riveted the spar assembly to the rudder with only rolling of the leading edge and riveting the trailing edge left to be completed on the rudder.
