I bounced around all over the place today in the manual. Ended up finishing the drilling, priming, and riveting of the yaw trim pushrod fairing along with deburring the spront spar in section 8. After the primer dried I then attached the left and right rudder skin along with using the VHB adhesive to join the rudder trailing edge. I let it sit clecoed to the aluminum angle for the night before riveting the rudder skeleton tomorrow. Hopefully I can then rivet the rudder trailing edge and call section 7 complete.
