Riveted the rudder spar per the directions. Used the rivet gun with tungston bucking bar. I am getting a lot better with the rivet gun. Still had one to drill out, a small smily or two and one spot that I nicked the spar reinforcement plate. Ended up sanding out the damage and will prime here shortly.
Plan to backrivet the skins, make the modifications for yaw trim to the rudder skin, then prime all the cuts and the backs of rivets before emplacing the skins. I also want to get an in progress inspection from an A&P before I close them up permenantly.
