Michael's RV-10 Build Log
RV-10
Ailerons
9-25-2005
Drilled, dimpled, alodined several parts
Ailerons are about 3/4 complete. Should be done in about another 6 hours.
You can see the stiffners in the trailing skins
Trailing skins attached to spar
Right aileron fitting assembly
RV-10 Home
1464
Ailerons
Avionics/Instruments
Avionics/Wire
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
485
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
