Michael's RV-10 Build Log
RV-10
Wing Spars
8-9-2005
Primed and completed spars
The main spars I felt were important enough to hit with a 2 part epoxy primer/sealer. They really didn't need it but of all the parts on the plane, these carry almost all the weight in flight and I really didn't want to risk any corrosion.
Tie down brackets
One of the spars primed
Tie down brackets attached
RV-10 Home
1464
Ailerons
Avionics/Instruments
Avionics/Wire
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
485
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
