Michael's RV-10 Build Log
Date:  7-5-2008
Brief Description:  Seat belt and electrical
Today I spent some time sanding down the aft hardpoints for the seatbelts and making the forward hardpoints. Waiting on some stuff from Aircrafty Spruce so I can lay down some S glass strips and set the points in place. I also secured the positive bat passthrough and added the negative which doubles as a ground point for the airframe.
Aft hardpoints sanded down and re-drilled
View of bat connections from inside the tunnel
View of connections from the engine compartment
