Michael's RV-10 Build Log
Date:  6-20-2008
Brief Description:  Misc cleanup from SB and hardpoint work
Re mounted the trim system that was removed for the SB, much happier with it now. Also did some finishing work on the ahardpoints and drilled and tapped the forward mount for a 8-32 screw. I think I'll change it to a 10-24 for a little more bite. The AL pad I put in helped out and did it's job.
