Michael's RV-10 Build Log
Date:  5-12-2006
Brief Description:  Static port connection and hat shelf.
I wanted to get the staticports connnected, at least in the rear, so it would be one less thing to struggle with once the tailcone was attached. I am using Safeair's pitot static tubing which is basically just high pressure air brake lines. Nice kit though. As you can see in the picture I attached the T that joins the two ports to the top of one of the rear seat belt attach points. These won't be needed because I will be going with inertial belts instead of the stock belts. This mounting point for the T allows me to position the tubbing above the static ports which should help to keep water out of the system. I also did the final mounting of the hat shelf at this point.
Static ports plumbed
Hat shelf installed
Hat shelf installed
Another view of shelf
