Michael's RV-10 Build Log
Date:  5-1-2006
Number of Hours:  1.50
Brief Description:  Mounted ELT, made gaskets for heat boxes
Well I decided to stick with the common location for the ELT and so I mounted it on the tail deck. The little bracket for the portable antenna popped right off when bumped so I mounted it right in front of the elt with some E6000. I also took apart the heat boxes and made a little gasket with some red RTV. Looking at the design of these things I can see why there may be a heat problem. When the cabin heat is closed the air is simply dumped overboard providing a steady stream of hot air to heat up the firewall and boxes. If this actually stopped the flow it would make a huge difference. Once I have the engine mounted I may look at a way to provide a diverter valve to shut off the heat flow and allow for cool air to flow through instead. This would also allow for mixed heat control to the cabin.
Ring of red RTV to form gasket
Wax paper for release agent
ELT mounted
ELT mounted
