Michael's RV-10 Build Log
RV-10
Tail Cone
6-27-2005
Began disassembly of tail and deburring
Discovered a crack in the F1010 bulkhead. Looks like the drill bit missed the flange hole and bent it around causing the crack. Ordered new bulkhead from Vans
RV-10 Home
1464
Ailerons
Avionics/Instruments
Avionics/Wire
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
485
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
