Michael's RV-10 Build Log
Date:  6-2-2006
Number of Hours:  5.00
Brief Description:  Primed and soundproofed, misc stuff
Today I shot some DP40LF on the floors and baggage door. Basically I am priming anyplace where water could sit and puddle but that's about it. The Alodine treatment will be the majority of my interior metal protection where I don't paint. Once that had cured I showed Amy how to spray on the QuietCoat soundproofing material. This can go a little slow because it is basically like spraying an undercoating. Very thick stuff. While she was doing that I messed around with the hinge for the hat shelf and rear bulkhead cover. I also cut the cover in half to form a door. The part that goes over the hatshelf will be held closed using thumb turn camlocks.
While I covered this subject in the past, I have had some questions around the soundproofing material. The material I am using for soundproofing comes from a company called www.quietcoat.com. It is basically a liquid form of the same stuff they make TempurFoam products from. When it's sprayed on and dries it gives a very good sound deadening effect through absorbtion in addition to the usual weight deadening. A quick primer on sound proofing. Basically all of the popular sound proofing products are a asphalt impegnated fiberglass mat. They are adheared to the exterior surfaces and work simply because of their density. Density = weight in this case and weight is bad in an aircraft. The QuietCoat stuff is a good balance between weight and performance. I also didn't want a product that could trap water between it and the aluminum. When this stuff dries it is very weather resistant.
View of the sides with sound deadening material sprayed.
View into the seat and baggage compartment wells.
Rear bulkhead cover cut in half and the hinge.
