Michael's RV-10 Build Log
Date:  3-31-2006
Number of Hours:  1.50
Brief Description:  Put down final two coats of QuietCar
I gotta say, I really like this stuff. Considering how viscous it is I thought it would be a pain to spray but it goes on real nice and controllable. You really need the gun they sell for this stuff. So anyway I put down a total of three coats in this section and it dries fairly quickly for a water based product. It's even fairly humid today. The stuff goes on in a textured form so keep that in mind. It also dries to a dark grey but it can be painted over. I simply taped over places where two pieces of the aircraft still need to come together and it peeled off in a nice line. More importantly the stuff seems to work as advertised, which is nice after the possible failure of the ceramic additive. The directions say it can take up to 7 days for the stuff to fully cure and reach it's full potential but it already made a very noticable difference. If I tap the firewall or sides where this stuff is sprayed I get a very dull thud and that's it. No high pitched ping at all.
Here you can see where I had taped for the panel ribs.
Here is a closeup that shows the texture and thinkness.
I also sprayed the underside of the floor panels to reduce the chance of that space acting like a drum
