I ran the lines for the AoA and Pitot. I'll also be running the trim cable through the same grommets as the AoA as it only has a couple of ribs to pass through. A lot of people just put in exit points for cables in the conduit but I decided to run some of the stuff seperate for ease of install. It's unlikely that either tubing will ever degrade in my lifetime.
AOA passes through main spar. The two wires are for the HID landing light.
AoA meets up with the Pitot run.
AoA and pitot exit. Black tube is regular wire run.
