Michael's RV-10 Build Log
Date:  10-14-2008
Number of Hours:  1.50
Brief Description:  Door work and lock swap
I've been really slacking lately but in fairness I've had to travel a bit in Sept and then AMy was gone on business which means I have the kiddos and I can't get to the shop. SO today I did some more prep work on the doors. I scraped off the QuietCoat where the sturt attach plate goes and drilled all the holes around the doors out. I have a check out to the list to see if Cab o Sil is basically the same thing as West Collodial SIlica so I don't have to order any Cabosil up special for this stuff. I also was finally able to pick up 3 matching locks from Home Depot to use as the locks on the doors. I had a lock for the baggage compartment from Aircraft Spruce but the POS was binding bad internally and I really wanted a matched set all around. For the cost of the one from AS I got all three from HD.
Holes drilled
Holes drilled
Shells temporarily joined
Strut mounting plate
