Today I did the install of the windscreen. I went with the Lorde urathane adhisive, same as the other windows. Some people use Silpruf but most don't use the Weldon method that Van's recommends. Not only is the Weldon 10 difficult to work with, it slins over very quickly and even Weldon say it's not the proper use of it. So I was able to get the upper and sides put in with the Lorde and I went with the standard epoxy with a structural filler along the bottom. All in all I'm happy with how it turned out and I'll let it se for a couple days before I remove the clamping.
I also did some other misc work in the engine compartment. Primarily adding a few more wedge clamps on a couple wires and hoses. I also started to final install the oil cooler.
