Michael's RV-10 Build Log
Date:  7-9-2006
Number of Hours:  3.00
Manual Reference:  43
Brief Description:  More trimming and fitting
Well I have now spent about 5 hours on this cabin lid and still haven't even got it to fit. Honestly it isn't too bad but the manual saus you need to remove it to about 1/16 of the radius around the door openings and in reality you probably need to take part of the radius off. A good starting point would be to flush the whole lip up with the rest of the structure. I can see fitting and cleanup of this thing easily taking 30 hours. Add to that the console and the hard points I am putting in for the rear seatbelts and this is going to be a 50 hour chapter. For those of you doing this in milder tempuratures, i highly recommend you do it outside. It's about 97 here today so I wasn't about to and now I have a nice layer of dust on everything. You could also tent the space if you have the room.
Still needs more taken off.
Tight fit.
Tight fit.
Hopefully the final amount to be removed.
