Michael's RV-10 Build Log
Date:  7-7-2006
Number of Hours:  1.00
Manual Reference:  40
Brief Description:  Finished up flap system install.
I decided to finish up the flap install on my lunch break seeing how it was really just a matter of cutting a couple of spacers and bolting it in place. I will say that you need to cut the spacers shorter than what is listed in the plans. Start with the size listed and then see what your install needs. I still have to install the Ray Allen position sensor for the Aircraft Extras FPS Plus. This is a flap positioning system that automatically adjusts the pitch trim as the flaps deploy. One less thing to worry about in a busy cockpit if flying an approach.
Motor installed and fully extended.
Motor fully retracted.
