Michael's RV-10 Build Log
Date:  6-5-2006
Number of Hours:  1.50
Manual Reference:  33 & 34
Brief Description:  Misc items and baggage tie downs
I reattached the platenuts where the wing fairing mounts from way back when i took them back off to get the fuselage side skins on. I also did a little cleanup of the rear bulkhead cover and figured out how many camlocks I would need so I can order them today. Lastly I didn't like the fact there really aren't any tiedowns in the baggage compartment and I wasn't about to spend the $$ for the tiedowns Van sells so I simply used some u-bolts that are double nutted with a locking washer between them. Drops most of the way into the floor when not in use and should work good. Hopefully my conduit will show today so I can finish up the floors and baggage door.
Tie down view from under the floor.
Top view.
Top view.
