Michael's RV-10 Build Log
Date:  3-10-2006
Number of Hours:  1.50
Manual Reference:  29
Brief Description:  Final drilled the mid skins to the longerons and o
Got the mid skins all match drilled this morning. They are also drilled to the four longerons. Everything is fitting well and there are no problems now that I reset those ribs. Also final drilled the mid fuse longeron to the gusset securing that in place.
View of the final drilled right skin.
Inside view of the same skin.
Upper mid fuse longeron drilled to gusset.
