Michael's RV-10 Build Log
Date:  3-2-2006
Number of Hours:  1.25
Manual Reference:  29
Brief Description:  Completed bending the longerons
I rebent the two lower longerons for the fuselage and they cam out great this time. Probably wouldn't have had a problem in the first place if I would have matched the pictures up to what I was doing. Oh well, no harm no foul. I also sent an email to Van's asking them about another instruction that was light on details. When you bend the fuselage skins you clamp it between two pieces of angle to hold things straight. Problem is they don't tell you which angle to use or if the kit even came with it. I don't want to chop up a piece I need later so I dropped them a line on it.
Upper and l;ower longerons resting in place
View from aft.
View from aft.
