Brief Description: Rivet F-1004K, mount gear mounts
Well I thought I was going to finish up Chapter 28 today but I ran into a problem mounting the right gear mount. It appears that the forward brace leg is just a tic out of alignment which is causing it to hit the forward seat brace before it is completely in place. This is keeping any of the bolt holes from lining up. I sent an email to Van's with pictures so we shall see what they say. Another funny thing is you are to match drill the F-1004K with the shim and gear mount but there are no holes where the diagram shows so I asked them about that also.
Top view of the interference. Looks like you would need to remove a lot of material in the seat brace
