Back from holiday and along with that came my panel inserts finally. I'm still fitting instruments so I'm not sure if they are good yet but I did run into a couple issues. First the MH Oxy controller had the side angles cut a little short. Some carefull dremel work fixed that problem and it really isn't noticable. The second problem that I need to address is the VP unit has a pan head screw sticking out the bottom which is going to make a clearence issues with the GNS-430W when I mount that. I also remounted the modified crank sensor for the ignition. I had Klaus add the skip plate that is now standard on the units which makes them a little beefier also. Lastly I installed the plug in the forward oil pan for inverted pickup and also replaced the oil pan drain/pickup with the new T that would give me the clearence needed for the pickup hose and accomedate the quick drain.
